939 series 14.00 x 20 air pressure
Csm Davis
382
Hattiesburg, Mississippi
Okay this got brought up in a different thread and because it is a safety issue I thought it deserves it's own thread.
The -10 says the wreckers should have 90 psi on highway, but the wheels are marked 85 psi maximum. I have looked at many different wheels and have not found any marked higher than 85 psi. I personally have run some higher than that and found that I popped the o-ring on some and feel lucky not to have blown a wheel apart as I just noticed the stamp about a month ago. Here's a couple of pictures.
infidel got me
34
Newberry, Florida
If your already aired up to 90 psi. cold, by the time you factor in heat transfer from the road you are way over 85 psi.
I never caught the rim stamping either.
Thanks for the post, you may have saved us a lot of grief, and maybe a few lives as well
goldneagle
931
Slidell, LA
The question is: Do we inflate to the maximum 85 PSI or go maybe 80 PSI? What about the lighter trucks in that series like the M923?
Csm Davis
382
I will keep mine at 80 until I get to the bottom of this.
The 923 uses 70 psi if memory serves. My 931A2 inflates to about 80.
This primarily is for 936A1 and A2 wreckers, all other 939A1 and A2s are to run 70 psi for highway use but can be adjusted for load.
jonesal
Mission Specialist
69
Brookings, SD
**Edited fro accuracy based on Post 13** (I put my glasses on)
With the exception of the M936, the current -10 TM (dated 31 July 2012) shows 11.00x20 (A0) 90 psi front and 70 rear for highway and 14.00x20 (A1/A2) 70 psi front and 70 psi rear for highway. It shows the M936 as 90 psi both front and rear for A0/A1/A2. See pages 0002-18 to 0002-20.
Al Jones
'84 M923
tbar123
24
enon,oh
I also found the same stamp on 2 different type of wheels ,That I installed the 14's on. I almost didn't see it either until I took a smoke brake after flipping one and started to air it up. The paint was just enough to cover it from plain sight.So I keep mine at 70psi.
MtnSnow
14
NSL, UT
Depending on what version of programming your CTIS unit has it will be 60 or 70 psi for the hwy setting for the Non wrecker trucks...
70 psi is the current programming version
