Finally got my injection pump sorted out, fired her up, and GOAL!!!! She makes a beautiful sound!
And then the bad smoke started.
The rectifier (Figure 4-13, Operator Maintenance Manual) for the day tank fuel solenoid was gushing out nasty white smoke. ("Use extreme care, should a selenium rectifier malfunction, to avoid inhalation of poisonous fumes.")
No internal wiring diagram dataplate on this machine. And the wiring diagram in the copy of the manual that I have is thoroughly illegible.
And, the previous owner generously repainted it prior to turning it over to me. Inside and out. It's all yellow. Any useful markings, labels, or identifying numbers on wires or terminals or anything else are now gone.
So, anyway.... the fuel solenoid rectifier has four wires going to its three terminals. Resistance between the outer terminals and the middle terminal -- with all wires still connected -- is ~125 ohms with multimeter pos. wire on the middle terminal and ~200 ohms with pos. wire on either outer terminal. This does not align with the manual, but perhaps I should disconnect all the wires first. Tomorrow, if the rain stays away.
Any help, especially including a legible wiring diagram, would be much appreciated.
