roveroverme
Banned
- 350
- 0
- 0
- port saint lucie/ florida
That blue wire goes down to the starter solenoid, right? maybe there is a break in it??? I gotta check that
I understand that part. But I am asking why we are not replacing the defective relay as a fix to the failure. I have had Ford trucks do the same thing and they have the same type of relay/solenoid. They would crank and burn them selves out until you got under the hood and disconnected the batteries. Please I am having friendly debate. I had a guy sell me his M1008 because a US quarter (coin) fell down in the dash and shorted across a solenoid replacement similar to what you are showing and burn the truck up while he was in the house. I found the quarter with the melted part while I was stripping the dash out. I don't have pictures. Never thought of it. I did wonder what the Ford solenoid was doing under the dash of a CUCV.Please do not take this as argumentative.
I know that I have had a couple of the stock relays fail in this manner. Along with many other people. A fellow member posted this picture. I guess you are just a lucky son of a gun to have never had a failure. Yes there are thousands of the originals out there and a few failures. Maybe it is like the current GM ignition switches. Not all of them have failed.
Also there are many ways to "fix" the issue. The DH Relay modification is just one way.
I thought the purple wire went to the solenoid.That blue wire goes down to the starter solenoid, right? maybe there is a break in it??? I gotta check that
We are replacing the relay.But I am asking why we are not replacing the defective relay as a fix to the failure.
Explain this again.I have a blue wire and what looks brown or pink (maybe???) on one post
was looking at the wrong wiring post. I've edited itExplain this again.
There should only be one wire on each stud/terminal of the under dash relay.
I am not talking about the Relay…As has been stated before, schematics are in the back of the -20 and -30 TMs. Relieve all doubt by using them.
Simple terms, 2 big wires go on the 2 big studs. The 2 small wires go on the 2 small studs.
It makes no difference which side any of them are on.
as Per the instructions on how to do the relay, I DISCONNECTED THE BATTERIES FIRST!DH makes a good point about disconnecting the batteries before doing this conversion. It is *very* easy to short out that 24v wire and burn out one or more fusible links.
I think it would be a good idea to get a voltmeter and start testing connections on the relay, both key off and key in crank position. There is not enough data to determine where the problem lies.
I do not understand this.I unhooked all battery terminals from both pos.
Because MY starter does not start.I do not understand this.
You should have removed both negative terminals. That's 2 wires.
Why are you doing anything with that pink wire? Who said to test it.
Back up and slow down here. I asked you which wires you disconnected because you posted that you disconnected them when you changed the relay.Because MY starter does not start
Back up and slow down here. ...You need to slow down and state the facts as we ask for info.
My first thought is that it is the noise suppressor that goes between the 24v Positive terminal block and the the Negative terminal block behind the rear battery.
If it is then it is not needed unless you are running the military radios. But I could be wrong. 4" makes it too long.
What type of material is it? Is it braided wire? Is that a rubber covering? Is it flat?
See? You never answered his questions about the strap. Instead, you are running on ahead.If the Relay is bad, shouldn't it start when I bypass the two large posts?
I just took this piece out that was between the two posts and was going to ask what it is.
So that isn't a fusible link or so? just a noise surpressor? I'll put it back then
