rustystud
- 3,077
- Woodinville, Washington
Then why do you care what where trying to do with installing check valves in the filter housing ?I'm not buying squat. I already have anti drain back filters.
There is no evidence that this was a design intent. Remember, both the oil cooler and filters have bypass valves to deal with cold viscous oil. It isn't necessary for the oil trapped to drain and be heated.I'm a fan of oil filters that drain. Just think of an oil pan heater that will then heat all the oil for an easy start in the Winter without bypassing the filters, where the oil may otherwise be to viscous to flow. IMHO, the reason they were designed to drain in the first place.
I appreciate what you are trying to do but isn't what you are trying to do the same as what is already provided by the anti drainback filter? What would the opening pressure of the anti drainback be?Then why do you care what where trying to do with installing check valves in the filter housing ?
Probably. But it just might be a couple hundred bucks cheaper.I appreciate what you are trying to do but isn't what you are trying to do the same as what is already provided by the anti drainback filter?
On a modern filter the antidrain valve requires maybe 1 psi to open. Probably not even that much. It's just a rubber flap that serves as a check valve.I appreciate what you are trying to do but isn't what you are trying to do the same as what is already provided by the anti drainback filter? What would the opening pressure of the anti drainback be?
The filter will let the oil drain forward, then you have an empty filter. I know, most of the damage is done prior to me owning it, but I can try to make it better...I appreciate what you are trying to do but isn't what you are trying to do the same as what is already provided by the anti drainback filter? What would the opening pressure of the anti drainback be?
For those who do not want to convert to spin-on filters this will be an engine saver.I appreciate what you are trying to do but isn't what you are trying to do the same as what is already provided by the anti drainback filter? What would the opening pressure of the anti drainback be?
I have tried to upload the spec sheet for 2 days now, and it will not go. I don't know if it's this site or my computer.Any pictures or catalog reference?
They fit perfectly. The reason I didn't install them all the way is I wouldn't be able to get them out without damaging them. The only one that needs any modification is the entry one. It needs a shoulder to land against or else it will go straight into the housing. The exit one will be pushed out towards the housing which has a smaller hole in the block. No need to do anything there. Drilling out a NPT hole is no problem. After the hole is drilled and tapped I would just install a 1/4" pipe plug with the end cut down a bit for the valve to set on.What about using a piloted bit to drill a flange into the steel?
All you would need is a lip about an eighth deep right?
