archmark
- 20
- 18
- Woodway, TX
Attached are pictures of the parking/emergency brake handle on my '66 M185A3. After reading prior posts on the forum, I'm thinking that this handle is the "early" style. What I'm not sure of is if there anything missing from it, like a cylindrical adjusting cover over the cable stem and bolt similar to the "late" style handles used to turn to adjust the brake tension or is this it? If this is in fact the complete assembly, do you simply adjust the nut until the brake holds or do I need to get under the truck and adjust the tension at the "drum"? Or should I just can this assembly and install one of the "late" style handles and cable, which appear to be a lot simpler?
Thanks...
Mark
Thanks...
Mark
