- 12,195
- 320
- 0
- gainesville, ga.
I made spade mounts on top of each side bed rail, so the spades can be accessed from the ground, it is a pain in the a$$ to climb up and down then climb over other stuff to access then return the spades that are mounted on the boom. It is EAISER, FASTER AND SAFER to access as much wrecker gear from the ground, and speaking of the ground, you know where the ground is when you fall down as compared to when you fall OFF THE WRECKER where it takes a second to find the ground.
Remember the spades are going to be full of dirt after use, if the situation NEEDED spades, there is going to a LOT of work going into the winching operation, so even if the spades are clean, they will still feel twice as heavy when they are placed in there brackets due to work of the winching operation.
