M1008 lift with factory steering
stevenf
louisiana
Bidding on an M1008 at the moment. If i get it i have plans for 37" surplus tires with 2-4" of lift. I cant seem to find if the factoty steering will work with 4 " of lift or if crossover is necessary? Do i only need a drop pitman arm?
5,054
You'll actually want more lift to get into a crossover. The simplest adjustment would be the kingpin spacer. I'm running a kingpin spacer and drop drag link on mine with a 6-8" lift.
goldneagle
1,203
Slidell, LA
I lifted mine 4" to allow for 37" HMMWV tires and rims. Used an adjustable drag link for steering. Front hubs have 2" spacers to push the rims away from the inner wheel wells. Do some searches and you will find threads with a lot of info on how it is done.
stevenf
louisiana
Exactly what i plan to do but with aftermarket rims and fender trimming.
So your running stock pitman arm?
Skinny
492
Portsmouth, NH
I will tell you with my 4" over stock height that a 2" drop pitman is too much. I can't get my steering wheel centered because I run out of adjustment. It's not too far off but if I could get another half inch shorter in the draglink I'd probably have enough room to center up fine. If I had to do it again I'd probably use a drop draglink or maybe a 1" steering block. This is if you want to keep the stock push/pull. Granted mine rarely goes offroad. If you actually plan on wheeling it and want it to actually work...go straight to crossover and don't look back. I would consider it mandatory.
My next step will be some type of overdrive (probably NV4500) with crossover combined with pushing the axle an inch forward.
goldneagle
1,203
Slidell, LA
Yes stock pitman arm. If you are going with aftermarket rims you may not need the spacers. The rear can handle 37" tires without any lift. I ran mine with 37" in the rear only for 6 months without any issues. Just can't use the 4 wheel drive without matching height tires.
