- 4,300
- 3,132
- Fort Worth, Texas
That's what I had figured. Nothing like a fresh RRAD truck.Moved to 5 ton section.
You're not going to like this, but I'm afraid you're going to need to remove the PT pump and take it to a shop to have it repaired. That shaft/seal requires the pump to be torn down to repair/replace.
Nay, the truck has since moved on from my possession.Fuzzy, still got that pulse sender? I am in need of two for my electric upgrades to the 818.
Nope, the pump needs to come off, but not disassembled. the drive can be pushed out of the front cover by removing the drive coupling and lightly tap the drive gear/shaft out. Let me look around, there might be a set of tac drive parts in my box here or at work. There is a tool to remove the assembly without removing the pump, but it grabs the driveshaft, I think what is left of yours isn't enough for the jaws to grip. Leme look for that too.Moved to 5 ton section.
Don't worry, truck has been passed on.Nope, the pump needs to come off, but not disassembled. the drive can be pushed out of the front cover by removing the drive coupling and lightly tap the drive gear/shaft out. Let me look around, there might be a set of tac drive parts in my box here or at work. There is a tool to remove the assembly without removing the pump, but it grabs the driveshaft, I think what is left of yours isn't enough for the jaws to grip. Leme look for that too.
