- 9,580
- 218
- 63
- Dickson,TN
I've owned both Lincoln and Miller. Can't really say anything bad about either one of them. The only reason I'd pick one brand over the other is if a particular machine had some of the features I liked better than the other.
Having been around all types of welding, it seems most fab shops and manufacturing settings tend to use mostly Miller. On the pipeline you'll see mostly Lincoln with an occasional Hobart. You very rarely see a Miller out on the pipeline around here.
Personally, I think about the worst thing for a beginner to do is buy a cheap no-name welder. I'm what I'd call a decent welder. I've tried to weld with those cheap machines, and while I was able to make it work, they didn't produce a good arc and it was more difficult to make a decent weld. If you buy one of those cheap welders, it will make learning much harder.
Like has already been said many times, buy a used brand name welder if you can't afford new. Even some of the older welders are better than what you can buy new. In the smaller welders nowadays, most of even the name brands have gone to aluminum windings. Most of you older welders will have copper windings. Copper windings produce a better arc.
