cgtboy1988
- 0
- 0
- Tucson, AZ
Hi all,
I just picked up a M109A3 (sprag, I think LDT engine) a few months ago and have been reading a lot of threads getting ready to do some serious modification with the end goal of building a camper. Currently, my deuce has got air steering, but other than that is basically stock, and I will get some pics up soon. I have a Reddot AC unit ready to install (still figuring out how exactly I want to mount) and a huge roll of kevlar (just sitting around) that I may insulate the bed with. Also have a Ford 6.0 intercooler I am planning to add to the multifuel and spare Spicer transmission for testing/modification. Power thus far is more than adequate for my needs, but I would like to do some mechanical mods to up gear ratios (hopefully to cruise between 60-65 on wide open Arizona highways), increase reliability and longevity, and maximize fuel economy and range. Usage will mostly be on highways to meet up for events and occasional offroading trips all over Arizona, Nevada, New Mexico, Utah, and California's high Sierra (Lassen and surrounding forests mostly, maybe the Rubicon occasionally if I can get the truck to fit). Most likely will occasionally encounter monsoon mud, snow and ice, desert summer heat, and sand (basically all sorts of different bad conditions). At this point, I would really like to keep the multifuel due to its robustness regarding fuel and conditions like cold. I am not sure, but it appears that the multifuel also tends to be fairly efficient compared to other engines (with its high compression ratio)? Looking for any experience on MPG on repowers compared to multifuel if someone can chime in on that point. Maybe will tow at some point, but no current need except for relatively lightweight toys. I am still determining all of the mods I plan on doing, feel free to chime in with any suggestions or feedback!
Finished modifications:
Air assist steering
Kill switch in lock box
Air ride seats
Planned repairs:
Air pressure regulator needs adjustment and/or replacement
Fuel sending or fuel gauge needs fix and/or replacement
Oil gauge needs fix
Planned camper modifications:
Redo bed insulation and waterproofing
Rubber bed flooring (waterproof recycled rubber over treated wood)
200-300 gallon water tank
Water pressure pump
Water heater
Plumbing (as space allows)
Reverse osmosis drinking water filtration
Dual 12v battery banks
Inverter(s)
LED light replacements
Solar on roof
Wood burning stove
Cabinets/lockers
Extend box over cab
Cab/bed access
Roof/bed access
HAM radio
Electric air compressor
Lift gate or ramp of some sort
Planned driving modifications:
Cab and dash lighting
Cab headset system (looking to go for something like a helicopter system to run audio and passenger voice through)
CB radio
12v outlets
Intercooler
EGT gauge
Boost gauge
Maybe timing work (I have heard that timing on these may not be up to snuff?)
Maybe engine balance work
Replace head gasket with a stronger one
Reddot AC
Insulate cab
LED lights all around (including headlights if possible)
Fuel adjustment
Auto drain air valves
Transmission replacement or gearing adjustment
Taller wheels/tires (still deciding on what to do for these)
Extra alternator(s)
WMO (and maybe WVO eventually) filtration setup
Dual fuel tank (Diesel and WMO tanks)
Brake modifications? (drill drums, dual circuit modification)
Winch (still deciding, hydraulic? direct? don't think electric)
Injection (possibly water, propane, water/meth, most likely water/meth in low concentrations)
Offroad and camp lighting
Security cameras (and onboard computer) for backing up and security both
Oil system mods? (LDS style oil system, non-return oil filters, maybe even one of those oil centrifuges, etc)
Possibly switch to air shift t-case
Square hitch
Maybe suspension adjustment/modification
Mid axle lockout hub (maybe front as well if air shift swap)
I know this is quite an extensive list, but I will update with pics here whenever I get time to knock any of these out.
Air assist steering
Air ride seats
Planned repairs:
Oil gauge needs fix
Water pressure pump
Water heater
Inverter(s)
Solar on roof
Wood burning stove
Cabinets/lockers
Extend box over cab
Cab/bed access
Roof/bed access
HAM radio
CB radio
12v outlets
Intercooler
EGT gauge
Boost gauge
Reddot AC
Insulate cab
Fuel adjustment
Extra alternator(s)
Square hitch
