metalman50
- 0
- 0
- Clarksville,TN
Trying to start a MEP-803A very recently bought at auction. The main switch (S1) appeared to be replaced and wired wrong as when the batteries were hooked up nothing happened when turned to start, and the pump came on when the switch was turned to preheat. I rewired the switch and works as it should, except crank the engine, the panel light switch (S2) also does not have power. The Dead crank works s it should and the CB1 is not tripped. Does anyone have any recommendations or comments.
Thanks in advance
Metalan50
Thanks in advance
Metalan50
