blhar15
- 11
- 28
- Waterloo, IA
Anyone know where I can find some TM's for the M114 APC?
Thanks
Thanks
Moved your post to this thread since it's more appropriate. Have no idea what the TM number is for it.What is the TM's number?
Is there more than one TM?
So with the M114 being in service only for a short while and back in the 70's. It'd have the -10, -20, -30, -40, and possibly a -50.CARNAC said:The numbers before that are the 'level' of maintenance. 10 is user level, 20 is organizational, 30 is direct support, 40 is general support and some items will even have a 50 which is depot level. All this is old days stuff. In the last few years the military went to 2 levels of maintenance but I haven't seen how that changed manual numbers since it happened fairly recently. I do know that manuals for equipment already in service still uses the original numbering system.
I will have to look tomorrow.Is there a data tag with the Tm #s?
Do you still have these uploaded? I need them as well.Check you PM shortly. I'm uploading these to my FTP site for you.
TM9-2320-224-10 June 62
OPERATOR'S MANUAL
FOR
CARRIER, PERSONNEL,
FULL TRACKED: ARMORED, T1l4
(COMMAND AND RECONNAISSANCE)
(2320,-860-2349)
TM9-2320-224-10 Nov 64
OPERATOR'S MANUAL
FOR
CARRIER, COMMAND AN.
RECONNAISSANCE: ARMORED
Ml14 (2320-860-2349)
Ml14AI (2320-987-9536)
Ml 14A IEI (2320-93 W
TM9-2320-224-10-C2
TM9-2320-224-20
ORGANIZATIONAL MAINTENANCE MANUALFOR
CARRIER, COMMAND
AND RECONNAISSANCE: ARMORED, M114/M114Al
(2320-860-2349) (2320-987-9536)
M26 Cupola (M114)-24P
ORGANIZATIONAL, DIRECT SUPPORT, AND GENERAL SUPPORT
MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LISTS
(INCLUDING DEPOT MAINTENANCE
REPAIR PARTS AND SPECIAL TOOLS)
FOR
CUPOLA, POWERED, 20-MM GUN MOUNT, XM27
(2510-232-6165)
CUPOLA, POWERED, CALIBER .50,
MACHINE GUN MOUNT, M26
(10942271)
CUPOLA, MANUAL, CALIBER .50,
(10935870)
Thanks, couldn't find them using my phone to navigate.
