mikey
- 39
- 28
- Lake Como, PA
I have a trailer with a 12k electric winch. I want to use it to winch up my 5ton M51A2 in the spring, which weighs about 23k.
In a perfect world I could use 2 or more snatch blocks and call it a day. The problem is that I only have 62' of winch cable.
If I had 100' I estimated using 2 blocks and three lines of equal length.
Snatch 1 (a) would need to be better than 24k, snatch 2 (b) better than 16k and the line pull would be 8k, good enough for the winch and the battery.
Since I only have 62' of line and the trailer length is 29' from winch to the ramp ends, I was wondering if I could do the following, please see my poor attempt at CAD.
If I put snatch 2 (b) in the middle of the trailer, I'll have enough line to get back to the bumper (c).
My question is, how does cutting the line lengthy in half, A to B and B to C, affect calculations? Or does it? I can't find any formulas.
I don't want to use a single block because it would require a 48k snatch block and it would put the line pull at 12k maxing the winch and probably the battery (300amp draw @ 12k).
Thanks!
Mikey
Thanks!
Mikey
