3/4" to 1" towbar adapter bushing
max1008
Blue Bell, PA
I picked up these bushings from Mcmaster-Carr. It found it very hard to find 1" towbar feet and the 3/4" feet are easily available. $13 each.
[h=3]The part number for Mcmaster is 3741K11- Oil-Lubricated Bronze Sleeve Bearing[/h]for 3/4" Shaft Diameter, 1" OD, 1-1/2" Length
Keith_J
1,319
Schertz TX
I found the same bushings at Tractor Supply back in 2012, now those parts assortments are no more as TSC. Did an inventory reduction and ended that rack jobber.
These bushings work great, flat towing the M1031 for 1500 miles was relatively easy. They had minimal wear after that trip so they should be good forever.
max1008
Blue Bell, PA
I wasn't sure if this has been covered, but I guess its always good to have an up-to-date part number.
I haven't had a change to check the fitment on an m35 or any other models.
goldneagle
989
Slidell, LA
I got a reducer from Tractor Supply in MS. They had it in the nut and bolt isle. Fit perfect. Using it for M715 tow bar feet so I can use the 3/4" feet along with it. I figure the 3/4" pins are plenty for a M715.
KsM715
142
St George Ks
What are you towing with it? I would be careful towing anything large that required 1" pins. Im no engineer but I wonder how much strength your losing by down sizing the pins?
goldneagle
989
Slidell, LA
Where can I find the feet for the tow bar? mine didn't come with any and was connected straight to the shackles
If you have a medium tow bar I have an extra set of 3/4" feet I can sell you. $80 shipped Priority Mail. If you plan to tow a larger much heavier truck you will need a set of 1" feet. I do not have any spare 1" feet.
porkysplace
1,493
mid- michigan
I don't think a 3/4 inch pin would be safe on a M35 or larger. CUCV 's and similar size trucks it will probably work.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
For your consideration on pin size. The length adjustments on the medium towbar use 3/4 pins. Just sayin.
goldneagle
989
Slidell, LA
People seem to forget that little fact.
Point well made sir. I do wonder if there are different forces applied tot the pins at the shackle mount than at the tow bar extension point. I am sure an engineer could shed some light on that. There is no twisting force applied at the extension but there might be a twist at the shackle mount when you make turns with the lead vehicle.
swbradley1
Modertator
1,708
Dayton, OH
I suspect that because the bar connects at the pintle at an angle there is more shear forces at play on the outside edge of the feet on the 1 inch pins. One side of the pin is trying to shear towards the back on the inside and towards the front on the outside.
Someone with a finite element modeling program on their computer could do an analysis for us. :)
Keith_J
1,319
Schertz TX
The forces are the same, double shear. No bending in the horizontal plane as they pivot in that axis. When lead vehicle is turning, the double shear is partially reversed which in no way compromises strength. Now if one foot fails, a much different situation happens.
Check tow bars at every stop and remember safety chains.
