WhitePhoenix
- 1
- 8
- Pensacola, FL
Gents, let me tell the tale to set the current scenario that presents itself to me right now. My deuce was bought and didn't run at the time. Well got everything buttoned up and went to start it for the 1st time, sparks shot out from the battery compartment but the engine did turn over. Closer inspection showed the connectors were cracked and weren't making good contact. Replaced them and went to try another start, the starter switch got a few cranks then the switch slipped due it not being tight to the dash, tightened it down and tried again, this time nothing. Looking through the tm's and broke out the multimeter to find the starter relay went bad, replaced it thinking my problem was solved but alas still nothing. Checked all the wires and ground, everything looks good. There is no clicking sound coming from the starter relay, so I'm thinking the switch is now bad, but any ideas are much appreciated.
