bcowanwheels
- 3
- 18
- KINGSPORT, TN.
does any of the 5 ton mil. trucks have clutch pedels ? reason I,am asking is I,d consider installing a rto-9515 or rto-9513 trans fuller and ditch all the military trans stuff.
Bob, Do your homework, These guys dont tolorate the spoon feeding like the other sites youve been on (OR, banned from) over the past few years. Read the Tech manuals and go junkyarding...does any of the 5 ton mil. trucks have clutch pedels ? reason I,am asking is I,d consider installing a rto-9515 or rto-9513 trans fuller and ditch all the military trans stuff.
If could have used a fuller, It would have been in the m819 YEARS ago, on the drivers side, there is just inches from the spicer and the front drive shaft, now that I am not running a front drive shaft, and will be replacing the rears with another set of rears with a different ratio, it looks like there will not be a front drive shaft at all in the future, now just need to find a trans with a side pto mount.The only fuller road ranger that might work would be RT 610 or RTO 613. They were put behind DT 466 and Cat 3208. Still might be too wide, I don't know. JT
Standard 34" outside rail to outside rail.How wide is the frame rails on one of these ?
If you found a front with the same ratio as you'll have in your rears, there is another possible solution. One of our fire trucks that is 4x4 has a power divider mounted on the rear axle flipped around so that it shoots a driveshaft forward and then it goes to the front axle via carrier bearings. This isn't the best setup for hard core offroad, and in this case was done because of length issues (pump takes up a lot of space!) but it is a solution to clearance issues with a transfercase on a transmission.If could have used a fuller, It would have been in the m819 YEARS ago, on the drivers side, there is just inches from the spicer and the front drive shaft, now that I am not running a front drive shaft, and will be replacing the rears with another set of rears with a different ratio, it looks like there will not be a front drive shaft at all in the future, now just need to find a trans with a side pto mount.
5 something, power divider, air brakes, controllable locking, should be a late spring/summer build, hope to be done in time for the 15SSGAR73M819 what ratio ?
My transfer case will be already driving a power divider for my yet to be installed rear winch, but that is a thought that I had not thought of. a pto off the power divider, or a splitter.Hey Ron what about a power divider off a 816 and running it backwards so that the extra output runs forward or even a regular transfer case from a 4x4 and run it off of your transfer case PTO.
