m923a2 Gear Oil in Air filter canister??
Lccountryboy89
Lincolnton, GA
Hey guys fully servicing my newly acquired 1991 m923a2 today. Changed both fuel filters and got it back running without problem (thank God). But when I opened the canister to look at the air filter I noticed there was a large amount of what seems to be gear oil inside the bottom on the case and seems to be in where that plastic turbine is? I thought this was a closed system from the intake cab above the cab so just wondering where this oil could be coming from? Don't want to have a runaway engine so trying to figure out the source and how to fix it... any input would be appreciated!
Scar59
41
Mt. Eden, KY
Some units filled the air cans with a small amount of oil to capture dust and debris. I would clean it out and go on.
Coffey1
497
Gray Court SC
Mine was doing same thing its the interlock leaking and pressurising the t-case and pushing gear oil out the vent.
Bypassed air to it no more oil.
timntrucks
119
Ponchatoula LA
i will be checking the air filter on my 925a2 and ill check to see if there is any oil in my canister. l would like to know more about the bypass
M35A2-AZ
392
Tonopah, AZ
My M936 is doing the same thing. I talked with Coffey1 some time back and we talked that it maybe the interlock, that is the one on top of the Transfer case.
I have not been able to get to my interlock on the M936.
