Sounds like your truck is coming along there. Where did you get your unloader parts? A cummins dealer? Do you have any part #'s from doing your fix for the unloader? Thanks for the response!
No part numbers. I took the unloader to an auto parts store and ended up with a gasket sheet and cut my own. I didn't replace anything else. I cleaned everything up and lubed the moving parts. I had my unloader stick on me before so the copper colored slider got special attention. All the seals were in good shape, I don't have a local Cummins dealer, and don't like to wait for shipping so I just went for it.
The first time I tore it apart I just replaced the gaskets and it leaked pretty bad. The second time I used new gaskets and hardening gasket sealer. It still leaked just as bad. This time I used a new gasket and silver Permatex RTV gasket maker. Now I just have a little foam on one side with soapy water spray.
The gasket at the compressor head has held fine (below the two coolant lines and the air outlet). It was just the gasket at the unloader that was causing problems and leaking. I put a bead on both sides of the gasket and finger tightened it like the directions said. I let it sit for about two hours and tightened it up. I also spread some on the shanks of the bolts as it leaked there too. Then it sat overnight.
With very little leaking the compressor definitely has more time between cycles. My secondary tank holds pressure much better too. It used to be empty overnight but now it stayed up at 70 psi. The primary usually stayed up there overnight. It may be unrelated but it is a change.
I wasn't sure if the silver Permatex was the one to go with over the red, so time will tell. I probably wouldn't have had so many issues if I got factory gaskets but it is what it is.
