M35a2 3 GROOVE PULLEY FOR AIR COMPRESSOR OR ALTERNTOR PART SOURCE????
61sleepercab
Walton, West Virginia
Does anyone have a part number or source for a 3 groove pulley for either the alternator or air compressor pump ? I am trying to add power steering to a Deuce and may run a one groove power steering pump for power? I may add a 12 vt alternator at the same time. Any help would be appreciated. Mark
red
25
Eagle Mountain/Utah
For the power steering fluid requirements its kind of hard to pass up on the pump from the 5ton trucks.
With a 12 volt alt TM America makes the brackets, multiple threads in this section about a 12volt system.
rustystud
2,962
Woodinville, Washington
You really don't want to run your pump that fast. The diameter of the air compressor pulley is close to 8" or more. Way too fast ! You don't want to use the alternator pulley since you will be adding to much strain to a unit that is already pulling a lot of HP to turn. Use a 5 ton pump assembly like others have said. You won't regret it.
61sleepercab
I may run Char Lynn power steering power generator type system and 5 ton pump would have to have psi reduction for use and lots of excess flow for Char lynn system. I may go with power steering box but I do not want more in power steering than whole truck cost. PS I have the multifuel power steering pump and drive gear, but it is over kill for some applications. Thanks for the input. Mark
