- 34,010
- 1,822
- GA Mountains
This is mine with 255/85R/16 BFGs on 7" wide rims. Works fine with no lift kit.
Looks good! Will that work on the stock rims?This is mine with 255/85R/16 BFGs on 7" wide rims. Works fine with no lift kit.
Any downside to a narrower rim? Thanks for the info! Love this new truckYes, they will fit and work fine on the stock 6 1/2" wide rim. I went with factory Ford rims for that extra half inch in width.
I'm not in a position to rebuild it myself. Just very basic mechanical skillsThe 208 is one of the easier to rebuild. Don't need a press. The pricing seems high but I can't compare, I do all my own work.
You can install it yourself- that's a $300 bill in your pocket. Don't forget they're going to tell you your U-joints are shot and your drive shaft need to be rebalanced.I'm not in a position to rebuild it myself. Just very basic mechanical skills
Not sure there is any antenna equipment on it. I believe it is only currently being used for a mount for the fuse box attached to itThat power plug looks like one used on kenwood vhf uhf radios. Any chance we can get a pic of where the antenna goes?
