cucvrus
- 10,434
- Jonestown Pennsylvania
I have been installing quad shocks on the front axle of every M1009 that I have and had in the past. I have been slowed from the installation the last few years because of lack of parts. I think LMC makes one side but not the other. I think it makes a difference with the front end bounce off road. My son was at a U-Pull it and saw a quad shock on a K10 pick-up. He cut the rivets with the grinder and was charged $5. US for the set. WOW what a deal. View attachment 550849The 3/8" holes are already in the frames to mount these brackets. The bottom bolt is longer and has a spacer to keep the shocks apart. I use grade 8 bolts and the spacer. The shocks are available at any parts store. They are longer then the primary stock shock as pictured on my barn M1009. View attachment 550850View attachment 550851Easy update if you can find the brackets. I wanted to share this with you so you can look while you are out in the salvage yards. If you are interested. If not fair enough have a nice day.
