- 805
- 71
- 28
- Kennewick, WA
I am in. I will commit to one set.
In order to put one on a rear axale, EITHER rear axle, you'll have to modify the axle shaft.Just curious, if each of you would like to share - are those of you that are ordering more than 1 set doing so for multiple deuces or are you also locking out the forward tandem axle?
Thanks for confirming this. That's my understanding too - one would need a whole new double spline axle shaft (splines on both ends because the stock axle shaft is part of the hub), like Ouverson's sells:In order to put one on a rear axale, EITHER rear axle, you'll have to modify the axle shaft.
