PowerstrokeNC
- 1
- 18
- Greensboro, NC
I am having an unusual problem with the Grove crane on the FMTV wrecker.
When I first go to use the crane, naturally I activate the PTO switch on dash, system fires up and all is good.
However for some reason the crane 'lift' operation and the boom lift operation will sometimes not work.
So since the crane is folded, you need the lift circuit to bring it out of its folded state, as well as the boom lift function to get the boom at the right angle.
A couple of notes; ALL the other functions work 100% boom lower/hoist up down/rotate etc. Also all the wrecker functions work 100% too.
So what I have done recently is shut off the PTO, let the rpms settle back to idle count to 10 and re engage. Count to 10 and disengage. Then after 10 secs & re engage again.
After this little sequence the lift and boom lift work no problem as they should, so I am scratching my head.
I thought well maybe its the valves that supply those functions, but the opposite function works i.e. boom raise doesn't work or works very slightly, but boom lower works fine. Same with the crane lift function, won't work, but the crane lower seems to work fine.
Also in case it helps the functions are partially working, they sort of 'start' to move but then stop. Almost like they don't have full pressure.
Nevertheless though once I go through the PTO engagement cycling everything works fine.
Any thoughts?
Any thoughts?
