skav
- 0
- 6
- Castaic/CA
So I've been researching MVs for a few years and really want a 5t A2. I've narrowed it down to a 925 or 932. He are my plans for using it, and where I need help.
Right now, I pull a 34' bumper pull toy hauler to the desert 5-6 times a year with maybe 2 trips out of state. The trailer weighs 16k loaded with fuel and water. The current tow vehicle is a 2500 duramax. Honestly, it tows the trailer well, but it's working the truck. I thought would be to get a 925, or 932' loose the rails and modify a drop side bed to fit and I'd like to run 16.00s to help raise the cruising speed. Then I'd fab a 30k hitch similar to a toterhome.
Here are the questions...
1. Will this setup work well on the highway as a puller? I have been leaning towards the 932 because it would be lighter than the 925 and has a higher tow rating.
2. Can I cruise comfortably at 65-70 without over running the motor? This is where I figured that the 16.00s work help a bit over the 14.00s
3. I'd also end up playing with the motor. How much can I turn up the pump without issues? I'd be adding EGT and boost gauges.
4. What advantage if any is there to loosing one of the rear axles? What would this do to the towing capacity?
5. What options are there for AC? I've seen roof units that I'm sure I could retrofit.
Any other advice, or anything that I'm missing?
