- 3,022
- 226
- 63
- eldersburg maryland
UPDATE - engine is mounted and about half hooked up, just some simple things to do now, fuel lines routed but need fittings, need to get gas pedal assy from donor truck it will just be the easiest and best way. need to flip radiator mounting side channels to the rear and fab a mounting brace. as luck would have it the trans rear flange ended up less than 1/16 of an inch from where it started!! hope it is drivable by end of week.
