OK, since photos from the phone work, I figured I will post Them separately here, then edit this post...
First the front view. I love that it has a winch since the photos I see without, they just look naked. Second, is it standard that they used a piece of railroad rail for the bumper like that, or was it someone's home fabrication?
This side gives another view of the rear roll cage in scale, as well as a shot of the temporarily high mounted radiator that I would have to relocate for tour work. I need my driver to be able to see the passengers one way or another.
Rear view. I know they aren't stock, but I feel the after-market tail lights may be necessary for approval for commercial tour operations...
The fuel injected 454 700R4 tranny are a tight fit, and the much bigger than stock radiator can't slot in without some additional work. One suggestion was to replace the standard water pump and pulleys with some slim line units. That, or swap back to the shorter stock 3 speed tranny which would come with the sale. However, since the clutch peddle assembly is missing, I think I would keep the auto, and see if I can't trade a friend the 454 for a short block 350 and gain several inches... maybe even room enough for a mechanical fan...
This is a different view of the radiator and the empty hole in the back of the tractor since there is nothing there right now....
View from the other side showing just how little room the current engine/tranny combo allows..
The current condition of the bed with spare. One 20 gallon fuel tank on the driver's side is currently being used. The passenger side is not connected at the moment and would at least require a boil, it's pretty gummy. The owner of the shop suggested simply pulling the tank and mounting the spare in it's place to keep the whole trailer open for passengers. I know this wouldn't be stock at all, but could be functional for my needs, but I don't know yet.
That is what I have at this time. I am thinking of going down to do a longer, more complete photo survey and driving test this evening. Anyone have additional thoughts about this particular unit, my plans, or what you would do with it if you were me?
