M35 Fuel Pump
olbucksnort
Bowling Green, VA 22427
Thank Yall.
I'll pull it out after I use up the 50 gal. that's just filled it.
I keep an Aux Fuel Trans Pump around for refueling things
for Emergency. For now it's good non-leaking storage tank !
"Years ago in my better days" I would of remembered to pull
things apart and inspect em' before you try to drive out of
the Motor Pool. I'm finding my retirement brings a subtle
humbling.
Thank's for not Pulling Rank on me Guy's
Sincerely,
Ol'Bucksnort.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Its in the cover on top of the pump. Should be 3 nuts that hold the cover on. Pretty sure its the housing the plug wires plug into.
olbucksnort
Well..... Found the blown fuse and replaced it 3 times ; first w/7 amp ; second w/10 ; third w/15 and going a call it quits (ran out a fuses) I thought it used a 12 amp?
I'll try and pull the pump one day.
rustystud
2,988
Woodinville, Washington
The fuse is only a 2 amp slow blow. Like jeepsinker said, get a new fuel pump and hose while your in there.
olbucksnort
Thank yall.
I'm off to Aberdeen this week to find one.
Glad I got a Portable Fuel Transfer Pump to
move all the Diesel I just filled the Tank with.
Looks like good weather for Aberdeen.
Glad to see everyone again from East Coast Convoy .
