Doomsday
- 0
- 0
- Castaic, CA
What temperature should the Allison 5 speeds in these trucks typically run at?? Either my gauge is wrong or 250-275 is normal.
I bought the truck not too long ago and did a full maintenance job on it. Cooling system was very corroded from the previous owner running straight water. Trans cooler had a bunch of sediment, was pretty clogged up and I figured that's why trans was running hot. Cleaned out cooling system, all new hoses and fresh distilled water and coolant. Changed trans fluid and filters but getting it out on freeway today it was again running in the 250-275 range. Isn't that too hot or is that normal?? If its too hot, any ideas what is causing it??
