rustystud
- 2,987
- Woodinville, Washington
I needed extra carrying capacity for Coolant and possibly fuel. The problem is the deuce does not have to many places to attach a spare can too. I have seen photos of Vietnam deuces with the fuel cans hanging off the rear mud flaps and thought that would be a good idea. I know there is someone making a kit now for this, but at the time I built this there was none. Mine just consists of a piece of 10 gauge steel plate (27"X15") with a spare fuel can carrier attached. It works really well. I also used the strap bracket seen in picture 4 that allows the strap to cinch down really hard to prevent any movement of the can. I used holes already drilled whenever I could. I also had to shim out the plate 5/8" from the mud flap due to the folds in the plate. I used 3/8" hole X 5/8" thick heavy bushings. You can also just use washers stacked up to accomplish the same thing. Now if I ever loose a water hose I can replace all the coolant lost. I always carry extra hoses.
You can also see the spot lights I bought from gimpyrobb. The two on the hitch are for reverse lights. The two mounted high up on the bed are for working at night.
