tourus
- 2
- 18
- madison me.
Ok so this is kind of long but here it goes.. 85 m1010
so back in late February early march 2015. I put new head gaskets on my 6.2.I got it to start but it smoked real bad. things got a little better after just running it quite hard for a few miles. got it good and hot and " clean it out". so after a few days I decided that I had an injector leaking.. thought that since it over heated caused by the head gasket . so put new 6.5 marine injectors in still smoked bad. going down the road or idling. drive down the road stop at a red light. step on the pedal to get going the cars behind me could not see anything for a mile or two after I got going. well do to life had to keep driving the old girl. so finally made an appointment to have timing check. due to real rough idle and not a lot of power and lots of white smoke. lots of white smoke. and the rich smell of fuel. so get to the shop to have timing reset and checked the guy says that it was not the timing but something with the valve train. IE. broken rocker arm or bent push rod or one of the rocker arm plastic retainer broke or some thing like that OK. drive the truck home got both valve covers off one side had a broken rocker arm and the other had a broke in half push rod. and one of the lifter pushed up and was laying side ways in the engine.
OK so now here is the question?? can a new lifter and retainer be put in with out taken the heads off that side?? 56800 miles on engine.
so what does everyone thing can this be done or not.
