I bought a Garwood winch from a reputable SS'er whom I trust. He had rebuilt the winch, but his wife preferred the deuce without it, so it got shelved. Some undisclosed amount of time later, I bought it (a year? several years?) I finally got around to installing it on my truck, and went for the first test run yesterday.
I pulled the drum lock out, and engaged the winch clutch (moved it to the 'IN' position) and then engaged the PTO from the cab.
No movement from the drum when powered in forward or reverse. PTO spins the shaft no problem. With the oil fill plug removed on the drivers side I see the gear turning slowly. Looks good.
I can spin the drum by hand, so I know it is free, but it doesn't seem to want to spin under power.
I've read the manuals; and many, many posts, but cant find anything like this. Any thoughts on what could be causing it? I'm ok with the answer being: "You skipped step X, you're an idiot....." In fact that would be a lot better than "You have a gear reversed in the housing, sorry. Take it all apart and try again...."
Any thoughts?
Any thoughts?
