- 1,651
- 1,664
- Nova Laboratories, WA
You're SUPPOSED to thin with water, and not thinner or chemicals, since it's water based..The paint is somewhat self leveling, but it was too warm outside to allow it to do that
That is why you use Flo-trol (with the water based paint) and stay out of direct sun.
TW, I didn't remember the Behr having instructions that say one can thin with water. It is really thick so spraying would seem to be an issue if it is not thinned.
[h=3]Application[/h]
- Apply product on dry substrates when air and surface temperatures are between 35°-90°F (2°-32°C) and will remain between 35°-90°F (2°-32°C) for at least 4 hours after applying.
- Do not paint when rain or heavy condensation is expected.
- Stir paint occasionally. Intermix containers of same product to ensure color and sheen uniformity.
- On semi-smooth surfaces, use a high quality 3/8-1/2” nap roller cover, nylon/polyester brush or an airless sprayer (.015-.021” spray tip, 60 mesh filter).
- On rough surfaces, use a high quality 3/4-1” nap roller cover.
- Do not thin if using a roller or brush; however, if using a sprayer and thinning is required, thin with water at a rate of no more than 1/2 pint per gallon.
- Certain colors may require more than one coat for complete hide.
- On heavy stains and woods that contain tannins, allow 12-16 hours of dry time between coats. Cooler temperatures or higher humidity may prolong drying time.
- After 4 weeks, cured paint film may be cleaned with a mild, non-abrasive liquid detergent.
- Dry paint film is mildew resistant.
- When applying to vinyl, color choice must be the same color or lighter than the existing color. Do not use on floors.
http://www.behr.com/consumer/products/exterior-paint-and-primer/behr-premium-plus-ultra-flat
