SS member Artisan was building some very nice hi speed low drag aux. light switch panels, using m923 style switches and warning lights. I want one of his setups really bad, I am adding off road lights to my M923A1.
snip
Thank you for the compliment Lindsey...
Looks like my ad in the classifieds was purged and
I need to make a new one. Till then here are some
pictures.
I drew these in AutoCAD . They all get precision cut w/ a water-jet
machine, then I take them to a sheet metal shop and get them bent.
I am 5-10 and 240# and I have no issues w/ my shins hitting them at all.
The large one is fixed, but your free to put it anywhere you want,
the smaller ones you can move around, they too have some mounting
holes that fit some trucks.
The large one has one switch w/o an idiot light, (3rd from the left),
that one you would use for a light in the cab, it will be obvious that
light is on so no idiot light is needed.
You supply all the switches and
lights and wiring and of course installation.
I used a heater switch and a diode and was able to pull off a high
and low beam switch for my IR's and I powered things w/ the 2 future
hot feeds an M925A1 has. One was for dual fuel tanks for the tractors and
one was for rotating beacons for the wreckers I believe.
