lostinutah
- 0
- 6
- pleasant grove, utah
Boots??? Not sure I'll check in the morning. Doing the spin on tomorrow. Should be fun.
Did a search on winch mounts. Got a lot with harbor freight parts.. that's what I went withCould you please elaborate on front shackle?
Thanks, I was getting worried about the flapping.They do flap ugly when it is idling. Just reach over and give it a little throttle and the flapping goes away. Do you have good adjustment left on the alternator belts? Or are they just about out of adjustment? I just put new belts on my M1009 Mule and used different sizes and went to the 1/2" wide belt on the #1 alternator. I am very happy with the adjustment still left on the belt.
The belt on my M1008 is also flapping.Changed the belts on the M1028.
Pulled them off, got to the local parts store, got replacements and put the new ones back on.
After a few times of tightening and test running I believe the tension is good.
The drivers side looks like it's flapping around, but the tension on it is correct.
Old vs new.
I have that piece of sheet metal too.For Safety someone else (or original ?) mounted a piece of sheet metal under the top water hose of the radiator over the belt.
I don't have one.I have that piece of sheet metal too.
