gottaluvit
- 28
- 48
- Bethesda, OH (AKA: Flyover Country)
I was lubing my truck to day and noticed a grease fitting on the bottom of the steering box by it's input shaft. The only leak this truck has is that seal where the steering shaft goes in the box. Figured maybe some lucas power steering sealant/revitalizer would go in when it needs added to. So I shot some grease in that fitting and it came out of the box where the shaft goes in.
Does grease being pumped into this fitting stop any leaks or is it a real bad sign I will have to rebuild the box since the grease came out? Is the box as easily rebuildable as it looks? Is there available rebuild kits or seals I need?
Any help appreciated,
Jim
Jim
