- 1,704
- 411
- 83
- Leavenworth, KS
MWMULES makes the occasional trip up to Riley as well. He may have a contact in the area.
If you receive good service from them, you should post their info for others that may need assistance getting a truck from that location.I found a tow company about 15 min away that is going to go get the truck and move it to their yard
I absolutely will tomorrow if everything goes well-very helpful so far!If you receive good service from them, you should post their info for others that may need assistance getting a truck from that location.
Flew in fine, got to the truck. Could NOT get it jumped off. Spent 2+ hours replacing batteries and it still would not start. Worked on it another hour before finding the manual engine shutdown tripped on the engine (was pushed in in the cab). Got it running and stopped all along the way to Kansas City trying to find air for the low tires. Finally found a trucker with the glad hand air chuck. While airing tires found oil running down the frame and dripping on ground. That was a loose filter on the passenger side. Tightened that up now I am in Advance Auto parts off 435 charging my phone before temping this again.
