rustystud
- 2,806
- Woodinville, Washington
View attachment Scan0062.pdf A number of people have contacted me about the brake light switch I used on my system. So I decided to post it here. The first picture is the drivers side air-pac and switch. The second picture is the passenger side air-pac and switch. The reason I went to this switch and didn't reuse the military switch is because the military switch is a high pressure switch. It is meant to operate at pressures up to 3,000 psi. The problem is when you remount it to the trucks air system which only reaches 120 psi max. A lot of times it will fail to turn on causing no brake lights. This switch I used is a standard civilian truck air brake switch which turns on at 4 psi. (3-5 psi). I just wired it into my system and it works great. The cheapest price I found was at "anythingtruck.com" .
