- 6,862
- 697
- Stratford/Connecticut
Factory horn didnt work so I swapped the small horn behind the bumper for a Federal Signal speaker and put in a Whelen 100w airhorn/pa. Air horn honks from factory button still. Added some cheapo led lights in front, I have some nice CAT hid lights they were a bit too big to squeeze in that location though. I wired them with a relay to come on with the high beams. Added a keyed momentary start switch. I added led blinkers all around the truck already had the new style controller. Swapped the reverse light for leds. I had to disconnect the passenger side one though, the two of them were a bit much for the circuit. Down the line I can find the wire going back and add a relay. I want to add some more forward lighting I only have around 2 inches to play with or I wont fit thru many of the local RR underpasses though. Not alot of ventilation in the cab I have some small dual fans with louvered covers I was going to try and make a vent system on the back of the cab where a window would go.
