- 6,965
- 2,479
- Montevideo/Uruguay
Yes, CCW - looking rear to front of engine.I just checked and yes the flywheel does turn counter clockwise. Is this the same direction as the m35? or is mine spinning the wrong way?? I sure hope not.....
Why so? Spinning "the wrong way" wouldn't be any different than for example coasting (in 5th and clutch depressed) then releasing the clutch. A sound transmission will stay in gear, either way.It would make sense for it to push itself out of 5th if it was spinning the wrong way.
G.
