- 14,248
- 1,690
- Dayton, OH
Based on Monrovia's elevation of 571' above sea level I doubt you are going to change the boiling point of water much from 100 degrees C (212F) and a couple of degrees on checking the temp of an engine is not going to matter. If it does...you are running a little too close to the edge.Thank U Davis, that is close to right I am sure,
but factory calibrated and certified gauges might work
a little better. It boils down to cost certainly...
I appreciate the input!
Cube of ice (H2O) and boiling water just like Jeff said.
