GUYS, it is flat out STUPID to kill that warning device.
FWCD = Failsafe Warning Control Device . IdahoMotorpool
sells the new style cheap and if $100 is too expensive for
you then you really should consider selling your truck.
It is there for a REASON. There is a simple work around if
you hate waiting for your truck to build air pressure.
Simply get a GLADHAND and mount an air Chuck nipple to
the end w/ a VALVE in-between. (See pic below) Before you start your truck
you make SURE wheels are chocked and P-Brake is ON and
connect an air line to the DS front Gladhand on your truck and fillerup.
One minute or so later and your tanks are topped off, you disconnect
your air fill valve and start the engine and off you go. (Be sure to
be SMART and open the gladhand valve ON your truck prior and
remember to close it after you fill. The PS gladhand is always
vented w/ NO VALVE in front, look at it, you will see.)
Dollars to donuts the guys who kill these devices are pennyless and
do not own property and never will. Play ball the RIGHT way, do
it wrong and if you ever do own property and you get caught
w/ a bypassed FWCW while in a wreck and you could lose it all! This is a ligating
society and YOU CAN BE SUED for not keeping your truck roadworthy.
It is usually the FWCW that goes bad but you will be smart to replace
both sensors at both air tanks on the PS AND BE SURE TO PULL THE
GROUND AND CLEAN ALL SURFACES USING A PROPER INTERNAL/EXTERNAL
STAR WASHER . I think it was a #55 wire.
