for just guage lights get a voltage reducer ( VOLTAGE DROPPER DC-DC POWER REGULATOR - 24V DC to 12V DC CONVERTER - 10A | eBay )
I'm not sure if an equalizer is better, but on the M916A1, A2, and A3 trucks, the device is setup as an equalizer. I am in the process of changing my M916 to a 24v starter and will be using a 24v/12v battery equalizer. It will be set up essentially like the Freightliner M916A1/A2/A3s are. Below is what I am planning.Bringing back an old thread.
So if a device can be used as an equalizer or a voltage converter, it sounds like using it as an equalizer is your best interest, is that correct?
I ask because I just got a cooper battery equalizer and was thinking about using it as a 12v converter, but it seems like it would be better to keep the batterys individually maintained.
Any opinions?
You really shouldn't use an "equalizer" as a 12volt converter . The purpose of an "equalizer" is to charge the 12 volt batteries equally from a 24 volt source (alternator). Yes you can do it, but you will shorten the life of the unit. Our transit dept uses "Vanners" exclusively. They are great units but they do have a life expectancy just like batteries do. Ours are suppose to last 8 to 10 years of daily use.Bringing back an old thread.
Any opinions?
Why do you believe this will shorten the life? This is what the manual states is normal/ intended operation? Functionally, the battery equalizer is like any other DC-DC converter with the difference that the output voltage is exactly half of the input. As long as you are not exceeding the rated load, there is no problem.You really shouldn't use an "equalizer" as a 12volt converter . The purpose of an "equalizer" is to charge the 12 volt batteries equally from a 24 volt source (alternator). Yes you can do it, but you will shorten the life of the unit. Our transit dept uses "Vanners" exclusively. They are great units but they do have a life expectancy just like batteries do. Ours are suppose to last 8 to 10 years of daily use.
It was from a question I had asked of the "Vanner" rep. I had wanted to use one for my personal use so I had asked if it was possible.Why do you believe this will shorten the life? This is what the manual states is normal/ intended operation? Functionally, the battery equalizer is like any other DC-DC converter with the difference that the output voltage is exactly half of the input. As long as you are not exceeding the rated load, there is no problem.
Anything you can do to keep electronics cooler will help. For every 10°C increase in temperature, life is cut by half.
When the Vanner is used in equalizer fashion, the alternator charges through the series string of batteries, the equalizer only has to make up the slight difference in the charge basically just powering the loads (recall than in a series string the current wants to go through the whole thing, so in charging/running the 24V stuff you are also charging the 12V battery already - in this way the 12V loads through the Vanner appear to the batteries as a 24V load). When operated as a voltage regulator/DC-DC-converter, it is carrying the entire load of charging+operating 12V loads much like an alternator would. Harder work means more heat, heat+electronics=shorter life.Why do you believe this will shorten the life? This is what the manual states is normal/intended operation?
I get what you are saying about increased load, higher heat, etc. However, Vanner claims a load current rating in the 60-100A range. If you can't run even modest tens of amp loads without catastrophe, it sounds like a poorly engineered converter or wildly exaggerated capability.When the Vanner is used in equalizer fashion, the alternator charges through the series string of batteries, the equalizer only has to make up the slight difference in the charge basically just powering the loads (recall than in a series string the current wants to go through the whole thing, so in charging/running the 24V stuff you are also charging the 12V battery already - in this way the 12V loads through the Vanner appear to the batteries as a 24V load). When operated as a voltage regulator/DC-DC-converter, it is carrying the entire load of charging+operating 12V loads much like an alternator would. Harder work means more heat, heat+electronics=shorter life.
I have one of the 100A Cooper versions.Anybody have any experience relating to Vanner vs Surepower/Cooper when it comes to equalizer/converters?
I was asking about longevity, not if it could do the job. The units have a life expectancy of 8 to 10 years charging the batteries. If your using them hard as a power source then the life expectancy will go down. I think any brand of equalizer will be the same. The rep was just telling the truth I believe. That is why I went to a dedicated 12 volt system. 12 volt alternator and separate battery.Rusty, After reading the manual for the Vanner and Cooper systems: both are designed for powering external 12V loads. I'd say that your Vanner rep was confused.
