- 3,266
- 3,397
- NORTH (Canada)
Well, today's progress was six hours for 11 out of 12 exhaust manifold nuts and all intake hardware, flame heater removal and assorted other items.
I expected the exhaust nuts to pt up a fight, so I sprayed the suckers for a week and today heated the nuts up as hot as I could get them with a regular blowtorch and used a candle to melt paraffin into the threads. Cool down with water spray bottle. I shortened a 11/16 impact socket and could get at all lower exhaust manifold nuts with a wobble extension and the impact gun (intake manifold loosened). Worked fine for most nuts, except #4. The one at #4 is holding out. Of course it is the most fun one to get to.
I even made a metric 17mm "wrench" tool from a cut-short socket welded to an old wrench handle to get a wider 6 point grip on the nut (and 17mm is a tighter fit than 11/16)...no dice...the socket/wrench eventually slips. I always tighten before loosening...did not help on this one.
Any other tips? I am headed for the pool with a cold one right now because when I get angry, things break. I am planning to get a "nut cracker" and attack the nut with it on Tuesday.
