- 12,195
- 325
- 0
- gainesville, ga.
They will work on ALL the 5t front hubs, the 39, 809, 939 series, though you will have transfer issues with the 39 and 809 seriesI am interested in a set as long as they work on the A2.
DittoI'd be in for a set in the 1k ball park.
I'm sure MtnSnow and Ddmk18 are referring to CTIS compatibility. It doesn't look like it would work with the front CTIS arrangement on a 939A2.They will work on ALL the 5t front hubs, the 39, 809, 939 series, though you will have transfer issues with the 39 and 809 series
Yes tobyS and squirting truck there is a neutral position in a 809 series transfer case, you have to use it for the rear body on a wrecker. MyothersanM1 is correct about the removal of air to the transmission poppets that engage the forward or reverse Sprague it will completely disengage the Sprague and allow the front to freewheel.
