04mustang
- 9
- 18
- Lumberton/NC
It seems like you are an engineer or at least extremely familiar with engineering to be able to use solid works and programs as such.I've thought about putting the mt654cr from the m939 trucks behind it, but it's rated to 300hp, so would the 330ho from the c7 be too much engine or is 300hp rating a conservative number?
I would say that anything built within the last few decades has been engineered to have a safety factor in it. The rated amount of whatever is being rated is actually quite a bit less than what it can handle due to an engineered safety factor. If I'm remembering correctly it should be around 20%. So add 20% of the 300hp rating and that will be what it can really handle. But by doing this you loose the wiggle room for overloading.
Corey
