Jeepsinker
- 452
- 83
- Dry Creek, Louisiana
What's all this necrothreading debauchery about?
I would guess the outer ? I have gear oil coming out of the brake drum . Decent amount.Which seal do you think is leaking?
It looks like the sheet metal plate inside the drum exists only to catch grease and oil.
If you look behind the plate there are four slots that let the grease out onto the outside of the drum. If you do not clean out those slots then it will go to the inside of drum/shoes. This goes for the 5 ton too.
