So I finally got time to get one of the 802A's hooked up. This one is at the barn (less than 100 hours on it). The barn is fed from the load center at the house, and I am using a simple homeline interlock to allow a two pole breaker to be engage when the main breaker is off. That said, I believe I need to give the generator its own ground rod (there is not one at the barn).
I ran the generator prior to hooking it up and verified it is set up for single phase, 60 hz, all looks to be in order.
So, grounding rod or no grounding rod needed? I live in the lightning capitol of the world so....
Tip: You can get a small solar panel kit with a simple plastic mount on ebay for +- 30.00, and it will keep your batteries topped off.
