M35A2 injection pump install
Caseymikl
Fort piece Florida
Used the gun to measure temp. Gauge is in fact extremely wrong! Block got up to 180. Top hose got up to about 150 or so and bottom hose was at 100. That was just sitting idling no load, not moving. Ran for probably 25 minutes or so.
Caseymikl
Fort piece Florida
180 at radiator or block?
Also put 10 gallons of fuel in it on top of what ever was in there. Gauge started to work and showed 1/4 tank and then it went back to full. Assuming I have a loose wire or bad ground somewhere.
rustystud
2,964
Woodinville, Washington
The sender units in all these old trucks are pretty much toast. I ran new wires, installed a new gauge and a new sender unit. Now it is reading correctly.
