CUCVLOVER
- 9
- 38
- west Tennessee, just outside Milan
Good point.If you ever intend on flat towing keep then removable.
I carry a large enough wrench to take them off for what ever reason.
I never knew there are 2 different sizes. I would be interested in seeing a comparison pic if anyone has one?The front shackles are bigger or beefier than the rear ones. That's why the two different parts numbers. The rears are the round loop style while the front ones are like the lower front shackles on the m35a3. Don't know why they did this. But most cucvs will have the ones for the rear on all four corners. Just what I have seen. I personally use a large lock pin that has a threaded lock nut on the end just so someone could not just pull the pin and remove the shackle in two seconds, they will need a tool and work at it to get one.
I know this isn't the deuce forum but I can answer the question why the deuce rear shackles are smaller. They are for trailer safety chains, not sling lifting. Rear slings use the adapter that hooks onto the fixture on top of the springs.The shackles are the same size just the front ones according to the parts TM is just beefier instead of looking like round stock bent to shape its more of a triangler shape cross section wise. If you look at the m35a2 it's the same thing the front shackles are bigger than the ones on the rear. Never could get a answer as to why on both, I served most my time in maintenance units in the army in the 80s and 90s, the automotive sections were to concerned with just keeping up with all the issues coming their way to answer what they thought was a retarded question, so I stopped asking.
