This is about hydraulic heads, buttons, retainer clips, and a sophisticated mechanism.
So it is raining cats and dogs and lightning and nasty things out here, can't even get to the grill, and I am studying, Labor day noon. Oh, and the clothes dryer just failed.
I have always wanted to know how the fuel cutoff works without me having to take the truck apart to fix it after it broke. I want to know what can fail the mechanism. I have read all the posts I can find about the button, HH and the "lever" mechanism.
My anxiety is that one day I won't be able to shut it off normally, it would run away or I would have to crimp the fuel line to get it to stop which would damage the plunger/sleeve and I will have a dead truck.
So far I think this.
Start the engine once in a while, warm it up properly, idle it for five recommended minutes and
slowly pull on the engine shutdown cable. All this also leads me to ask ...........
"When is the most pressure and when is the least
pressure on the button and is the button ever supposed to see clearance between its surface and the flat tappet guide surface"?
I have attached four page PDF for your perusal to help answer my question.
View attachment fuel shutoff and the button 09072015.pdf
